crypto-map-ipsec-isakmp-instance
Applies an existing and configured IP access list to the auto site-to-site VPN tunnel or remote VPN client. Based on the IP access list‘s settings traffic is permitted or denied across the VPN tunnel.
use ip-access-list <IP-ACCESS-LIST-NAME>
| ip-access-list <IP-ACCESS-LIST-NAME> | Specify the IP access list name. |
Site-to-site VPN tunnel: nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#use ip-access-list test nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#show context crypto map test 1 ipsec-isakmp use ip-access-list test security-association level perhost peer 1 ikev2 ikev2Peer1 local-endpoint-ip 192.168.13.10 pfs 5 security-association lifetime kilobytes 250000 security-association inactivity-timeout 200 transform-set AutoVPN ip nat crypto nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)# Remote VPN client: nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#use ip-access-list test1 nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#show context ' crypto map test 2 ipsec-isakmp dynamic use ip-access-list test1 peer 1 ikev1 RemoteIKEv1Peer1 local-endpoint-ip 157.235.204.62 pfs 14 security-association lifetime seconds 10000 transform-set RemoteVPN remote-type none nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#
