wpa-wpa2
      Modifies TKIP-CCMP (WPA/WPA2) related parameters
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         wpa-wpa2 [exclude-wpa2-tkip|handshake|key-rotation|opp-pmk-caching|pmk-caching|
preauthentication|server-only-authentication|psk|sae|tkip-countermeasures|use-sha256-akm]
         wpa-wpa2 [exclude-wpa2-tkip|opp-pmk-caching|pmk-caching|preauthentication|
server-only-authentication|use-sha256-akm]
         wpa-wpa2 handshake [attempts|init-wait|priority|timeout]
         wpa-wpa2 handshake [attempts <1-5>|init-wait <5-1000000>|priority [high|normal]|
timeout <10-5000> {10-5000}]
         wpa-wpa2 key-rotation [broadcast|unicast] <30-86400>
         wpa-wpa2 psk [0 <LINE>|2 <LINE>|<LINE>]
         wpa-wpa2 tkip-countermeasures holdtime <0-65535>
         wpa-wpa2 sae hash-to-element
      Parameters
                     | wpa-wpa2 | Modifies TKIP-CCMP (WPA/WPA2) related parameters |
                     | exclude-wpa2-tkip | Excludes the Wi-Fi Protected Access II (WPA2) version of TKIP. It
                        supports the WPA version of TKIP only. This option is disabled by
                        default. |
                     | opp-pmk-caching | Uses opportunistic key caching (same Pairwise Master Key (PMK)
                        across APs for fast roaming with EAP.802.1x. This option is enabled by
                        default. |
                     | pmk-caching | Uses cached pair-wise master keys (fast roaming with eap/802.1x). This
                        option is enabled by default. |
                     | preauthentication | Uses pre-authentication mode (WPA2 fast roaming) |
                     | use-sha256-akm | Uses sha256 authentication key management suite |
                     | handshake | Configures WPA/WPA2 handshake parameters |
                     | attempts <1-5> | Configures the total number of times a message is transmitted towards a
                        non-responsive client
                           <1-5> – Specify
                              a value from 1 - 5. The default is 2. |
                     | init-wait <5-1000000> | Configures a minimum wait-time period, in microseconds, before the first
                        handshake message is transmitted from the AP. This option is disabled by
                           default.
                           <5-1000000> –
                              Specify a value from 5 - 1000000 microseconds. |
                     | priority [high|normal] | Configures the relative priority of handshake messages compared to other
                        data traffic
                           high – Treats
                              handshake messages as high priority packets on a radio. This is the
                              default setting.normal – Treats
                              handshake messages as normal priority packets on a radio |
                     | timeout <10-5000> <10-5000> | Configures the timeout period, in milliseconds, for a handshake message
                        to retire. Once this period is exceeded, the handshake message is
                           retired.
                           <10-5000> –
                              Specify a value from 10 - 5000 millisceonds. The default is 500
                              milliseconds.<10-5000> –
                              Optional. Configures a different timeout between the second and third
                              attempts' |
                     | key-rotation | Configures parameters related to periodic rotation of encryption keys.
                        The periodic key rotation parameters are broadcast, multicast, and unicast
                        traffic. |
                     | broadcast <30-86400> | Configures the periodic rotation of keys used for broadcast and
                        multicast traffic. This parameter specifies the interval, in seconds, at
                        which keys are rotated. This option is disabled by default.
                           <30-86400> –
                              Specify a value from 30 - 86400 seconds. |
                     | unicast <30-86400> | Configures a periodic interval for the rotation of keys, used for
                        unicast traffic. This option is disabled by default.
                           <30-86400> –
                     | psk | Configures a pre-shared key. |
                     | 0 <LINE> | Configures a clear text key |
                     | 2 <LINE> | Configures an encrypted key |
                     | <LINE> | Enter the pre-shared key either as a passphrase not exceeding 8 - 63
                        characters, or as a 64 character (256bit) hexadecimal value. |
                     | wpa-wpa2 | Modifies TKIP-CCMP (WPA/WPA2) parameters |
                     | tkip-countermeasures | Configures a hold time period for implementation of TKIP counter
                        measures |
                     | holdtime <0-65535> | Configures the amount of time a WLAN is disabled when TKIP counter
                        measures are invoked
                           <0-65535> –
                              Specify a value from 0 - 65536 seconds. <0-65535> – Specify a
                              value from 0 - 65535 seconds. The default is 60 seconds. |
                     | hash-to-element | Enable the use of SAE Hash-to-Element for password element
                        generation. |
         nx9500-6C8809(config-wlan-test)#wpa-wpa2 tkip-countermeasures hold-time 2
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid testWLAN1
 vlan-pool-member 1 limit 1
 vlan-pool-member 2 limit 1
 vlan-pool-member 3 limit 1
 vlan-pool-member 4 limit 1
 vlan-pool-member 5 limit 1
 vlan-pool-member 6 limit 1
 vlan-pool-member 7 limit 1
 vlan-pool-member 8 limit 1
 vlan-pool-member 9 limit 1
 vlan-pool-member 10 limit 1
 bridging-mode local
 encryption-type none
 authentication-type none
 wireless-client hold-time 200
 wireless-client cred-cache-ageout 65
 wireless-client max-firewall-sessions 100
 protected-mgmt-frames mandatory
 wireless-client reauthentication 35
 wep64 key 1 hex 0 7465737431
 wep128 key 1 hex 0 25f6e7ed9718918a87a75acc75
--More--
