radius-user-pool-policy
         Configures a RADIUS user pool and enters its configuration mode
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         radius-user-pool-policy <RADIUS-USER-POOL-NAME>
      Parameters
                     | <RADIUS-USER-POOL-POLICY-NAME> | Specify the RADIUS user pool policy name. If a policy with the specified
                        name does not exist, it is created. |
         nx9500-6C8809(config)#radius-user-pool-policy testRadiusUserPool
nx9500-6C8809(config-radius-user-pool-testRadiusUserPool)#?
Radius User Pool Mode commands:
  duration  Set a guest user's access duration
  no        Negate a command or set its defaults
  user      Radius user configuration
  clrscr    Clears the display screen
  commit    Commit all changes made in this session
  do        Run commands from Exec mode
  end       End current mode and change to EXEC mode
  exit      End current mode and down to previous mode
  help      Description of the interactive help system
  revert    Revert changes
  service   Service Commands
  show      Show running system information
  write     Write running configuration to memory or terminal
vnx9500-6C8809(config-radius-user-pool-testRadiusUserPool)#
      Related Commands
                     | no | Removes an existing RADIUS user pool policy |
For more information on RADIUS user
            group commands, see
RADIUS Policy.
