factory-reset
      Erases startup configuration on a specified device or all devices based
        on the parameters passed.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      factory-reset [config-all|config-device-only|deep|on <RF-DOMAIN-NAME>]
      factory-reset [config-all|config-device-only] [<HOSTNAME/MAC> {<HOSTNAME/MAC>}|
on <RF-DOMAIN-NAME> {containing <SUB-STRING>|exclude-controllers|
exclude-rf-domain-manager|filter <DEVICE-TYPE>}]
      factory-reset deep <AP-HOSTNAME>
      factory-reset on <RF-DOMAIN-NAME> {containing <SUB-STRING>|exclude-controllers|
    Parameters
              | [config-all| config-device-only] | Erases startup configuration and reloads only
                controller-adopted devices.
                  config-all
                    – Erases startup configuration on all adopted devices or on
                    specified adopted devices. Issue the command on the
                    controller or virtual controller AP. To execute the command
                    on a specified device, provide the device hostname/MAC
                      address.Note: This option
                      also removes the device's configuration staged on the
                      adopting controller. config-device-only – Erases only the startup configuration
                    on all adopted devices or on specified adopted devices.
                    Issue the command on the controller or virtual controller
                    AP. To execute the command on a specified device, provide
                    the device hostname/MAC address. Note: This option
                      only erases the startup configuration. It does not remove
                      the device's configuration staged on the adopting
                      controller. Note:
                  For more information on the actions performed by this
                    command, click here. |
              | <HOSTNAME/MAC> {<HOSTNAME/MAC>} | This parameter is common to the ‘config-all‘ and
                ‘config-device-only‘ keywords:
                  <HOSTNAME/MAC> – Erases startup configuration and
                    reloads the device identified by the <HOSTNAME/MAC>
                    keyword. Specify the device‘s hostname or MAC address.
                      <HOSTNAME/MAC> – Optional. You can optionally
                        specify multiple space-separated devices. |
                <SUB-STRING>|exclude-controllers|exclude-rf-domain-manager|filter
                <DEVICE-TYPE> | The following parameters are common to the ‘config-all‘ and
                  on <RF-DOMAIN-NAME> – Erases startup configuration
                    and reloads all devices or specified device(s) within a
                    specified RF Domain
                      <RF-DOMAIN-NAME> – Specify the RF Domain
                          name.After specifying the RF Domain, optionally use
                          the filters provided to identify specific device(s)
                          within the RF Domain. If none of the filters are used,
                          the command is executed on all devices within the RF
                          Domain. These filters are:
                          containing <SUB-STRING> – Optional. Executes
                            the command on all devices containing a specified
                            sub-string in their hostname
                              <SUB-STRING> – Specify the sub-string to
                                match. exclude-controllers – Optional. Executes the
                            command on all devices excluding controllers. Since
                            only a NOC controller is capable of adopting other
                            controllers, use this option when executing the
                            command on a NOC controller.exclude-rf-domain-manager – Optional. Executes the
                            command on all devices excluding RF Domain managers.
                            Use this option when executing the command on the
                            NOC, Site controller, or RF Domain manager.filter <DEVICE-TYPE> – Optional. Executes
                            the command on all devices of a specified type
                              <DEVICE-TYPE>
                                – Specify the device type. The options are: AP410, AP460, AP510,
                                AP505. |
              | deep | Resets an adopted AP's mode of operation to factory-default
                  setting (that is not specified). Issue the command on the
                  adopting WiNG VC/Controller and specify the AP' hostname. Once
                  the AP's mode of operation is reverted to factory-default
                  setting, the AP reboots and moves into the discovery mode to
                  determine its mode of operation. The WiNG 7.X AP410, AP460, AP505, AP510 and AP560 model access points have the
                  capability of operating in the following two modes: Distributed and Centralized. For a
                  newly-manufactured, out-of-the-box AP505 and AP510 access point the mode of
                  operation is not specified.  |
              | <AP-HOSTNAME> | Specify the hostname of the AP on which the deep reset is
                to be implemented. |
              | factory-reset | Erases startup configuration and reloads device(s) based on
                the parameters passed Note:
                exclude-controllers| exclude-rf-domain-manager| filter
                <DEVICE-TYPE>]} | Erases startup configuration and reloads all devices or
                specified device(s) within a specified RF Domain identified by
                the <RF-DOMAIN-NAME> keyword
                  <RF-DOMAIN-NAME> – Specify the RF Domain name. After
                    specifying the RF Domain, optionally use the filters
                    provided to identify specific device(s) within the RF
                    Domain. If none of the filters are used, the command is
                    executed on all devices within the RF Domain. These filters
                    are:
                      containing <SUB-STRING> – Optional. Executes the
                        command on all devices containing a specified sub-string
                        in their hostname
                            match.exclude-controllers – Optional. Executes the command on
                        all devices excluding controllers. Since only a NOC
                        controller is capable of adopting other controllers, use
                        this option when executing the command on a NOC
                        command on all devices excluding RF Domain managers. Use
                        this option when executing the command on the NOC, site
                        <DEVICE-TYPE> – Optional. Executes the command on
                          <DEVICE-TYPE> –
                            Specify the device type. The options are: AP410, AP460, AP505, AP510,
                            AP560, NX5500, NX7500, NX9500, NX9600, and VX9000. The startup
                            configuration is erased on all devices of the type specified here. For
                            example, if AP510 is the device-type specified, the command is executed
                            on all AP510s within the specified RF Domain. |
    Usage Guidelines
        (Actions performed by the factory-reset command)
      The action taken by this command depends on the parameters passed.
          - For the factory-reset
              [<DEVICE-NAME>|on <RF-DOMAIN-NAME>] options,
            the command:
              - Erases startup
                configuration on the target device (or) all devices in the
                target RF Domain.
- Erases the
                device configuration entries from the controller‘s configuration
                for the target device (or) for all the devices in the target RF
                Domain.
- Reloads the
                target device (or) all devices in the target RF Domain.
              config-all [<DEVICE-NAME>|on
              <RF-DOMAIN-NAME>] options, the command:
              - Erases startup
                target RF Domain.
- Erases the
                Domain.
              config-device-only [<DEVICE-NAME>|on
              - Erases startup
                target RF Domain.
      nx9500-6C8809#factory-reset config-device-only ap505-134038
In progress ....
Erased startup-config - success 1 fail 0
Successful device deletion - total 1
nx9500-6C8809#
      nx9500-6C8809#factory-reset deep ap505-13403B
In progress ....
reset ap deep - success 1 fail 0
nx9500-6C8809#
