Enforces data transfer limits on captive portal clients. This feature enables the tracking and logging of user usage. Users exceeding the allowed bandwidth are restricted from the captive portal.
data-limit <1-102400> {action [log-and-disconnect|log-only]}
         | data-limit <1-102400> | Sets a captive portal client's data transfer limit in megabytes. This limit is applicable for both upstream and downstream data transfer.
| action [log-and-disconnect| log-only] | Optional. Specifies the action taken when a client exceeds the configured data limit. The options are:
rfs4000-229D58(config-captive-portal-test)#data-limit 200 action log-and-disconnect rfs4000-229D58(config-captive-portal-test)#
rfs4000-229D58(config-captive-portal-test)#show context captive-portal test data-limit 200 action log-and-disconnect rfs4000-229D58(config-captive-portal-test)#
| no | Removes data limit enforcement for captive portal clients |
