crypto-cmp-cert-update
    Triggers a CMP
        (Certificate Management Protocol) certificate update on a
      specified device or devices
This command and its
        syntax is common to both the
User Executable and
Privilege
          Executable configuration modes.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      crypto-cmp-cert-update <TRUSTPOINT-NAME> {on <DEVICE-NAME>}
    Parameters
              | crypto-cmp-cert-update <TRUSTPOINT-NAME> on <DEVICE-NAME> | Triggers a CMP certificate update on a specified device or devices
                  <TRUSTPOINT-NAME> –
                    Specify the target trustpoint name. A trustpoint represents a CA/identity pair
                    containing the identity of the CA, CA specific configuration parameters, and an
                    association with an enrolled identity certificate. Use the crypto-cmp-policy
                    context mode to configure the trustpoint.
                       on <DEVICE-NAME> –
                        Optional. Initiates a CMP certificate update and response on a specified
                        device or devices. Specify the name of the AP, wireless controller, service
                        platform or virtual platform. Multiple devices can be provided as a comma
                        separated list.
                           <DEVICE-NAME> –
                            Specify the name of the AP, wireless controller, service platform or
                            virtual platform. |
      NOC-NX9500#crypto-cmp-cert-update test on B4-C7-99-71-17-28
CMP Cert update success
NOC-NX9500#
