no [class <EX3500-QoS-POLICY-MAP-NAME>|description]
    no <PARAMETERS>
| no <PARAMETERS> | Removes this EX3500 QoS policy map's settings based on the parameters passed |
The following example shows the EX3500 QoS policy map ‘test‘ settings before the ‘no‘ command are executed:
nx9500-6C8809(config-ex3500-qos-policy-map-test)#show context ex3500-qos-policy-map test description "This is a test EX3500 QoS Policy Map" class test nx9500-6C8809(config-ex3500-qos-policy-map-test)#
EX3500(config-ex3500-qos-policy-map-test)#no description
      EX3500(config-ex3500-qos-policy-map-test)#no class test
      The following example shows the EX3500 QoS policy map ‘test‘ settings after the ‘no‘ command are executed:
EX3500(config-ex3500-qos-policy-map-test)#show context ex3500-qos-policy-map test EX3500(config-ex3500-qos-policy-map-test)#
