This command is not available in the USER EXEC Mode.show upgrade-status {detail|on}
         show upgrade-status {detail} {(on <DEVICE-NAME>)}
         | upgrade-status | Displays last image upgrade status and log |
| detail | Optional. Displays last image upgrade status in detail |
| on <DEVICE-NAME> | The following keyword is recursive and common to the ‘detail'
                           parameter:
 Note: If the ‘on‘
                           keyword is used without the ‘detail‘ keyword, the system displays a
                           summary of upgrade status and log on the specified device. |
nx9500-6C8809#show upgrade-status Last Image Upgrade Status :In_Progress(17 percent completed) Last Image Upgrade Time : 2017-02-11 12:26:29 nx9500-6C8809#
nx9500-6C8809#show upgrade-status detail Last Image Upgrade Status : Successful Last Image Upgrade Time : 2017-06-02 14:22:51 ----------------------------------------------- Running from partition /dev/sda8 var2 is 1 percent full /tmp is 4 percent full Free Memory 33357504 kB FWU invoked via Linux shell Validating image file header Removing other partition Tue May 30 10:43:36 IST 2017 debug: cmdline -C /boot/lilo.conf -R 5.9.0.0-028B -P fix LILO version 22.6-CCB, Copyright (C) 1992-1998 Werner Almesberger --More-- nx9500-6C8809#
