ip
      Supported in the
            following platforms:
            - Service Platforms —
               NX5500, NX7500, NX9500, NX9600, VX9000
ip arp [header-mismatch-validation|trust]Parameters
                        trust] | Configures ARP related parameters on this port-channel interface
                           header-mismatch-validation – Enables a source MAC mismatch check in both the ARP and ethernet headers. This option is enabled by default.trust – Enables ARP trust on this port channel. If enabled, ARP packets received on this port are considered trusted, and information from these packets is used to identify rogue devices. This option is disabled by default. |
ip dhcp trust
                     | ip dhcp trust | Enables DHCP trust. If enabled, only DHCP responses are trusted and forwarded on this port channel, and a DHCP server can be connected only to a DHCP trusted port. This option is enabled by default. |
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#ip arp trust
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#show context
 interface port-channel1
  description "This port-channel is for enabling dynamic LACP."
  duplex full
  ip arp trust
Related Commands
                     | no | Removes or reverts to default the ARP and DHCP security parameters configured |
