Configures a trustpoint and its associated information, such as the subject name, the sender‘s (device requesting certification) details, and the recipient's (CA) details. This information is needed to obtain the certificate from the CA server using CMP.
Each certificate is digitally signed by a CA and contains device-specific information, such as device name, IP address, serial number. It helps to uniquely identify a device.
trustpoint <TRUSTPOINT-NAME> subject-name <WORD> secret [0 <WORD>|2 <WORD>] reference-id <WORD> sender-name <WORD> [recipient-name <WORD>|ca-psk <CERT-PATH>]
| trustpoint <TRUSTPOINT-NAME> | Configures a trustpoint name (should not exceed
                        32 characters)
| subject-name <WORD> | Configures a subject name for this trustpoint. The subject name should uniquely identify the certificate and should not exceed 512 characters in length. |
| secret [0 <WORD>|2 <WORD>] | Configures the secret used to encrypt the
                        trustpoint. The secret should not exceed 128 characters in length.
| reference-id <WORD> | Configures the reference ID. The CA server uses
                        this information to identify the shared secret key used.
| sender-name <WORD> | Configures the sender‘s name. The CA server uses
                        this information to identify the shared secret key used. The sender‘s name
| recipient-name | Configures the recipient‘s name. The CA server uses this information to validate the request. The recipient's name should not exceed 256 characters in length. |
| ca-psk <CERT-PATH> | Configures the certificate path for the server
                           certificate
ap6522-D8273A(config-cmp-policy-CMP)#trustpoint cmp-test subject-name "CN=Examp leCompany, O=Example Company" secret 0 test-secret reference-id 123456 sender-na me "CN=ExampleCompany.com, O=Example Company" recipient-name "O=Example Company, CN=ExampleCompany.com" ap6522-D8273A(config-cmp-policy-CMP)#
ap6522-D8273A(config-cmp-policy-CMP)#show context crypto-cmp-policy CMP cert-update cert-renewal-timeout 60 ca-server primary host 192.168.8.74 port 8 path cmp trustpoint cmp-test subject-name "CN=ExampleCompany, O=Example Company" secret 0 test-secret reference-id 123456 sender-name "CN=ExampleCompany.com, O=Example Company" recipient-name "O=Example Company, CN=ExampleCompany.com" subjectAltName dn TechPubsCA ap6522-D8273A(config-cmp-policy-CMP)#
| no | Removes the trustpoint associated with this crypto CMP policy |
