sms-over-smtp
    Configures an e-mail host server (for
      example: smtp.gmail.com) along with sender related credentials and the recipient gateway
      e-mail address to which the message is E-mailed. The gateway server converts the e-mail into
      SMS and sends the message to the guest user‘s mobile device.When sending an e-mail, the
        e-mail client interacts with a SMTP server to handle the content transmission. The SMTP
        server on the host may have conversations with other SMTP servers to deliver the
      e-mail.
        - Service Platforms — NX 75XX, NX 95XX, NX 96XX, VX 9000
Syntax
      sms-over-smtp [host|message|subject]
      sms-over-smtp host [<IP/HOSTNAME>|<HOST-ALIAS-NAME>] sender <EMAIL-ADDRESS>
security [none|ssl|starttls] username <USER-NAME> password <PASSWORD> recipient <EMAIL-ADDRESS>
      sms-over-smtp message <LINE>
      sms-over-smtp subject <LINE>
    Parameters
      sms-over-smtp host [<IP/HOSTNAME>|<HOST-ALIAS-NAME>] sender <EMAIL-ADDRESS> security
              | sms-over-smtp | Configures guest user SMS over SMTP notification
                settings |
              | host [<IP/HOSTNAME>| <HOST-ALIAS-NAME>] | Configures the SMS gateway server resource‘s IPv4
                address or hostname used for guest management SMS over SMTP traffic, guest user
                credential validation and pass code reception. Optionally you can use an existing
                host alias to identify the SMS gateway server resource.
                  <IP/HOSTNAME> – Specify the SMTP gateway server resource‘s IP address or
                    hostname.<HOST-ALIAS-NAME> – Specify the host alias name (should existing and
                    configured). Consider providing the host as an alias. A host alias is a
                    configuration item that maps the alias to a hostname. Once created, it can be
                    used across different configuration modes. Where ever used the alias is replaced
                    by the associated hostname. |
              | sender <EMAIL-ADDRESS> | Configures the sender‘s e-mail address. The sender here
                is the guest user receiving the pass code. Guest users require this pass code for
                registering their guest e-mail credentials using SMTP.
                  <EMAIL-ADDRESS> – Specify the e-mail address (should not exceed 64
                    characters). |
              | security [none|ssl|starttls] | Configures the encryption protocol used by the SMTP
                server when communicating the pass code
                  none – No encryption used. Use if no additional user authentication is needed
                    beyond the required username and password combination.SSL – Uses SSL encryption. This is the default setting.
                      STARTTLS – Uses STARTTLS encryption |
              | username <USER-NAME> | Configures a username unique to this SMTP guest
                management configuration. After configuring the username, specify the associated
                password. Ensure that the correct password is provided to receive the pass code
                required for registering guest user credentials with SMTP.
                  <USER-NAME> – Specify the username (should not exceed 64 characters). |
              | password <PASSWORD> | Configures the password associated with the specified
                SMTP user name
                  <PASSWORD> – Specify the password (should not exceed 64 characters). |
              | recipient <EMAIL-ADDRESS> | Configures the e-mail recipient's e-mail address
                  <EMAIL-ADDRESS> – Specify the recipient‘s e-mail address (should not exceed
                    64 characters in length. |
              | sms-over-smtp | Configures guest user SMS over SMTP notification message
                content |
              | message <LINE> | Configures the content of the SMS over SMTP sent to the
                guest user notifying the pass code (should not exceed 1024 characters)
                  <LINE> – Specify the message content. When entering the message, use the
                    following tags: GM-NAME – for the guest user‘s name  GM_PASSCODE – for
                      the pass code  CR-NL – to enter a new line  For example: Dear
                      GM_NAME, CR-NL your internet access pass code is GM_PASSCODE. CR-NL Use this
                      access code for internet access. |
              | sms-over-smtp | Configures guest user e-mail notification subject line content |
              | subject <LINE> | Configures the subject line of the SMS over SMTP sent to the guest user
                notifying the pass code (should not exceed 100 characters) |
      nx9500-6C8809(config-guest-management-test3)#sms-over-smtp host test sender
bob@extremenetworks.com security ssl username bob password bob@123 recipient john@extremenetworks.com
      nx9500-6C8809(config-guest-management-test3)#show context
guest-management test3
 sms-over-smtp host test sender bob@extremenetworks.com security ssl username bob password bob@123 recipient john@extremenetworks.com
