crypto-ikev1/ikev2-peer commands
Configures IKEv1/IKEv2 peer‘s authentication mode and the pre-shared key
authentication [psk|rsa]
authentication psk [0 <WORD>|2 <WORD>|<WORD>] {local|remote}
      authentication rsa
| psk [0 <WORD>| 2 <WORD>| <WORD>] {local|remote} | Configures the
                        authentication mode as PSK. The PSK is a string, 8 - 12 characters long. It
                        is shared by both ends of the VPN tunnel connection. If using IKEv2, both a
                        local and remote string must be specified for handshake validation at both
                        ends (local and remote) of the VPN connection.
 The following keywords are available only in the IKEv2 peer configuration mode:
authentication rsa
| rsa | Configures the
                        authentication mode as RSA This is the default setting (for both IKEv1 and
                           IKEv2). RSA is the first known public-key cryptography algorithm designed signing and encryption. If configuring the IKEv2 peer, the ‘rsa‘ option allows you to enable authentication at both ends of the VPN connection (local and remote). |
nx9500-6C8809(config-profile-default-ap8533-ikev1-peer-peer1)#authentication rsa nx9500-6C8809(config-profile-default-ap8533-ikev2-peer-peer1)#authentication psk 0 key@123456 nx9500-6C8809(config-profile-default-ap8533-ikev2-peer-peer1)#show context crypto ikev2 peer peer1 authentication psk 0 key@123456 local authentication psk 0 key@123456 remote nx9500-6C8809(config-profile-default-ap8533-ikev2-peer-peer1)#
