monitoring-interval
      Configures the interval, in seconds, at which clients are
         monitored to determine if their RSSI value is below the specified handoff-threshold
         value
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         monitoring-interval <1-60>
      Parameters
                     | monitoring-interval <1-60> | Specifies the interval, in seconds, at which
                        clients are monitored to determine if their RSSI is below the specified
                           handoff-threshold
                           <1-60> – Specify the duration from 1 - 60
                              seconds. The default is 5 seconds. |
         nx9500-6C8809(config-roaming-assist-policy-test)#monitoring-interval 40
         nx9500-6C8809(config-roaming-assist-policy-test)#show context
roaming-assist-policy test
 aggressiveness medium-high
 handoff-count 5
 detection-threshold -90
 handoff-threshold -75
 action log
 disassoc-time 7
      Related Commands
                     | no | Removes the configured monitoring interval details |
