Enables periodic pinging of the primary gateway to assess its availability. When enabled, the system continues pinging, an unreachable gateway, for a specified number of times and at the specified interval.
This option is disabled by default.
failover interval <1-250> retry <1-10>
| failover interval <1-250> retry <1-10> | Specifies the
                        interval, in seconds, between two successive pings to the primary gateway.
                        If the primary gateway is unreachable, the system pings it at intervals
                        specified here.
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#failover interval 200 retry 5 rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#show context gre tunnel testGRETunnel dscp 20 failover interval 200 retry 5 rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#
| no | Removes the GRE tunnel settings based on the parameters passed |
