crypto-cmp-policy
      Creates a crypto Certificate Management Protocol (CMP) policy and enters
        its configuration mode
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      crypto-cmp-policy <CRYPTO-CMP-POLICY-NAME>
    Parameters
              | crypto-cmp-policy <CRYPTO-CMP-POLICY-NAME> | Specify the crypto CMP policy name. If the policy does
                not exist, it is created. |
      nx9500-6C8809(config)#crypto-cmp-policy CMP
nx9500-6C8809(config-cmp-policy-CMP)#?
CMP Policy Mode commands:
  ca-server             CMP CA Server configuration commands
  cert-key-size         Set key size for certificate request
  cert-renewal-timeout  Trigger a cert renewal request on timeout
  cross-cert-validate   Validate cross-cert using factory-cert
  no                    Negate a command or set its defaults
  subjectAltName        Configure subjectAltName value
  trustpoint            Trustpoint for CMP
  use                   Set setting to use
  clrscr                Clears the display screen
  commit                Commit all changes made in this session
  do                    Run commands from Exec mode
  end                   End current mode and change to EXEC mode
  exit                  End current mode and down to previous mode
  help                  Description of the interactive help system
  revert                Revert changes
  service               Service Commands
  show                  Show running system information
  write                 Write running configuration to memory or terminal
    Related Commands
              | no | Resets values or disables commands |
