mac-address-table
      Profile Config Commands
Configures the MAC address table. Use this command to create MAC address table entries by assigning a static address to the MAC address table.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
mac-address-table [aging-time|detect-gateways|static]
      mac-address-table aging-time [0|<10-1000000>]
      mac-address-table detect-gateways
      mac-address-table static <MAC> vlan <1-4094> interface [<L2-INTERFACE>|ge <1-4>| port-channel <1-2>]Parameters
                        [0|<10-1000000>] | Sets the duration a learned MAC address persists after the last update
                           0 – Entering the value ‘0‘ disables the aging time<10-1000000> – Sets the aging time from 10 -100000 seconds. The default is 300 seconds. |
                     | mac-address-table detect-gateways | Enables automatic detection of gateways. Detected gateways are remembered in the MAC address table. |
port-channel <1-2>]
                        <MAC> | Creates a static MAC address table entry
                           <MAC> – Specifies the static address to add to the MAC address table. Specify the MAC address in the AA-BB-CC-DD-EE-FF, AA:BB:CC:DD:EE:FF, or AABB.CCDD.EEFF format. |
                     | vlan <1-4094> | Assigns a static MAC address to a specified VLAN port
                           <1-4094> – Specify the VLAN index from 1 - 4094. |
                     | interface [<L2-INTERFACE>| ge
                        <1-4>| port-channel <1-2>] | Specifies the interface type. The options are: layer 2 Interface, GigabitEthernet interface, and a port channel interface
                           <L2-INTERFACE> – Specify the layer 2 interface name.ge – Specifies a GigabitEthernet interface
                                 <1-4> – Specify the GigabitEthernet interface index from 1 - 4.port-channel – Specifies a port channel interface
                                 <1-2> – Specify the port channel interface index from 1 - 2. |
nx9500-6C8809(config-profile-TestNX5500)#mac-address-table static 00-40-96-B0-BA-2A vlan 1 interface ge 1
nx9500-6C8809(config-profile-TestNX5500)#show context
profile nx5500 TestNX5500
 bridge vlan 1
  logging facility local4
 mac-address-table static 00-40-96-B0-BA-2A vlan 1 interface ge1
 ip nat pool pool1
--More--
Related Commands
                     | no | Disables or reverts settings to their default |
