meshpoint-qos-policy
      Configures a set of parameters that
         defines the meshpoint QoS policy.
The
            WiNG 7.1.X release does not support Meshpoint configuration on AP5XX model access
            points. This feature will be supported in future releases.
Configured on WiNG 7.1.X controller
            and pushed to the following WiNG 5.9.X APs:
            - Access Points — AP7502, AP7522,
               AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8543, AP8533
Syntax
         meshpoint-qos-policy <MESHPOINT-QOS-POLICY-NAME>
      Parameters
                     | <MESHPOINT-QOS-POLICY-NAME> | Specify the meshpoint QoS policy name. If a policy with the specified
                        name does not exist, it is created. |
         nx9500-6C8809(config)#meshpoint-qos-policy test
nx9500-6C8809(config-meshpoint-qos-test)#?
Mesh Point QoS Mode commands:
  accelerated-multicast  Configure accelerated multicast streams address and
                         forwarding QoS classification
  no                     Negate a command or set its defaults
  rate-limit             Configure traffic rate-limiting parameters on a
                         per-meshpoint/per-neighbor basis
  clrscr                 Clears the display screen
  commit                 Commit all changes made in this session
  do                     Run commands from Exec mode
  end                    End current mode and change to EXEC mode
  exit                   End current mode and down to previous mode
  help                   Description of the interactive help system
  revert                 Revert changes
  service                Service Commands
  show                   Show running system information
  write                  Write running configuration to memory or terminal
      Related Commands
                     | no | Removes an existing meshpoint QoS policy |
For more
            information on Meshpoint QoS policy configuration, see
Meshpoint Policy.
