spanning-tree
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
spanning-tree [bpdufilter|bpduguard|force-version|guard|link-type|mst|
port-cisco-interoperability|portfast]
         spanning-tree [force-version <0-3>|guard root|portfast]
         spanning-tree [bpdufilter|bpduguard] [default|disable|enable]
         spanning-tree link-type [point-to-point|shared]
         spanning-tree mst <0-15> [cost <1-200000000>|port-priority <0-240>]
         spanning-tree port-cisco-interoperability [disable|enable]
      Parameters
                     | force-version
                        <0-3> | Specifies the
                        spanning tree force version. A version identifier of less than 2 enforces
                        the spanning tree protocol. Select one of the following versions:
                           0 – Spanning Tree Protocol
                              (STP)1 – Not supported2 – Rapid Spanning tree
                              Protocol (RSTP)3 – Multiple Spanning Tree
                              Protocol (MSTP). This is the default setting |
                     | guard
                        root | Enables Root
                        Guard for the port The Root
                           Guard disables superior BPDU (Bridge Protocol Data Unit)
                           reception. The Root Guard ensures the enabled port is a designated port.
                           If the Root Guard enabled port receives a superior BPDU, it moves to a
                           discarding state (root-inconsistent STP state). This state is equivalent
                           to a listening state, and data is not forwarded across the port.
                           Therefore, enabling the guard root enforces the root bridge position. Use
                           the no parameter with this command to disable the Root Guard. |
                     | portfast | Enables rapid
                        transitions. Enabling PortFast allows the port to bypass the listening and
                        learning states. |
                     | bpdufilter
                        [default|disable| enable] | Sets a PortFast
                        BPDU filter for the port Use
                           the no parameter with this command to revert the port BPDU filter to its
                           default. The spanning tree protocol sends BPDUs from all ports. Enabling
                           the BPDU filter ensures PortFast enabled ports do not transmit or receive
                           BPDUs. |
                     | bpduguard
                        [default|disable| enable] | Enables BPDU
                        guard on a port Use the no
                           parameter with this command to set BPDU guard to its default. When the BPDU guard is set for
                           a bridge, all PortFast-enabled ports that have the BPDU guard set to
                           default shut down upon receiving a BPDU. If this occurs, the BPDU is not
                           processed. The port can be brought back either manually (using the no
                           shutdown command), or by configuring the errdisable-timeout to enable the
                           port after a specified interval. |
                     | link-type
                        [point-to-point|shared] | Enables
                        point-to-point or shared link types
                           point-to-point – Enables
                              rapid transition. This option indicates the port should be treated as
                              connected to a point-to-point link. A port connected to a controller
                              is a point-to-point link.shared – Disables rapid
                              transition. This option indicates this port should be treated as
                              having a shared connection. A port connected to a hub is on a shared
                              link, |
                     | mst
                        <0-15> | Configures MST
                        on a spanning tree |
                     | cost
                        <1-200000000> | Defines path
                        cost for a port from 1 - 200000000. The default path cost depends on the
                        speed of the port. The cost helps determine the role of the port in the MSTP
                        network. The designated cost is the cost for a packet to travel from this
                        port to the root in the MSTP configuration. The slower the media, the higher
                        the cost. |
                     | port-priority
                        <0-240> | Defines port
                        priority for a bridge from 1 - 240. Lower the priority greater is the
                        likelihood of the port becoming a designated port. Applying a higher value
                        impacts the port's likelihood of becoming a designated port. |
                     | port-cisco-interoperability | Enables
                        interoperability with Cisco's version of MSTP (which is incompatible with
                        standard MSTP) |
                     | enable | Enables CISCO
                        Interoperability |
                     | disable | Disables CISCO
                        Interoperability. The default is disabled. |
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree bpdufilter disable
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree bpduguard enable
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree force-version 1
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree guard root
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree mst 2 port-priority 10
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
 interface ge1
  description "This is GigabitEthernet interface for Royal King"
  duplex full
 --More--
Related Commands
                     | no | Removes spanning tree settings configured on this interface |
