Configures an auto provisioning policy. This policy configures the automatic provisioning of device adoption. The policy configures how an AP is adopted based on its type.
auto-provisioning-policy <AUTO-PROVISIONING-POLICY-NAME>
| <AUTO-PROVISIONING-POLICY-NAME> | Specify the auto provisioning policy name. If the policy does not exist, it is created. |
NOC-NX9500(config)#auto-provisioning-policy test
NOC-NX9500(config-auto-provisioning-policy-test)#?
Auto-Provisioning Policy Mode commands:
  adopt                     Add rule for device adoption
  auto-create-rfd-template  When RF Domain specified by the matching rule
                            template does not exist create new RF Domain
                            automatically
  default-adoption          Adopt devices even when no matching rules are
                            found.  Assign default profile and default
                            rf-domain
  deny                      Add rule to deny device adoption
  evaluate-always           Set the flag to evaluate the policy everytime,
                            regardless of previous adoption status
  no                        Negate a command or set its defaults
  redirect                  Add rule to redirect device adoption
  upgrade                   Add rule for device upgrade
  clrscr                    Clears the display screen
  commit                    Commit all changes made in this session
  do                        Run commands from Exec mode
  end                       End current mode and change to EXEC mode
  exit                      End current mode and down to previous mode
  help                      Description of the interactive help system
  revert                    Revert changes
  service                   Service Commands
  show                      Show running system information
  write                     Write running configuration to memory or terminal
      | no | Removes an existing Auto Provisioning policy |
