ip (wlan-config-mode)
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         ip [arp|dhcp]
         ip arp [header-mismatch-validation|trust]
         ip dhcp trust
      Parameters
                     | ip arp | Configures the IP settings for ARP packets |
                     | header-mismatch-validation | Verifies mismatch of source MAC address in the ARP and Ethernet headers.
                        This option is enabled by default. |
                     | trust | Sets ARP responses as trusted for a WLAN/range. This option is disabled
                        by default. |
         ip dhcp trust
                     | ip dhcp | Configures the IP settings for DHCP packets |
                     | trust | Sets DHCP responses as trusted for a WLAN/range. This option is disabled
                        by default. |
         nx9500-6C8809(config-wlan-test)#ip dhcp trust
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 description TestWLAN
 ssid test
 bridging-mode local
 encryption-type tkip-ccmp
 authentication-type eap
 accounting syslog host 172.16.10.4 port 2
 data-rates 2.4GHz gn
 client-load-balancing probe-req-intvl 5ghz 5
 client-load-balancing band-discovery-intvl 2
 captive-portal-enforcement fall-back
 ip dhcp trust
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
 enforce-dhcp
 broadcast-dhcp validate-offer
 http-analyze controller
      Related Commands
                     | no (wlan-config-mode) | Resets IP ARP or DHCP trust parameters to default. ARP trust is
                        disabled, ARP mismatch verification is enabled, or DHCP trust is
                        disabled. |
