no [area|auto-cost|default-information|ip|network|ospf|passive|redistribute| route-limit|router-id]
no <PARAMETERS>
| no <PARAMETERS> | Negates a command or set its defaults |
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
The following example shows the OSPF router interface settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context router ospf network 1.2.3.0/24 area 4.5.6.7 area 0.0.0.4 auto-cost reference-bandwidth 1 default-information originate metric 1 metric-type 2 redistribute static metric-type 1 passive vlan1 route-limit num-routes 10 reset-time 10 ip default-gateway priority 1 nx9500-6C8809(config-profile default-ap8533-router-ospf)#
nx9500-6C8809(config-profile default-ap8533-router-ospf)#no area 4
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#no auto-cost reference-bandwidth
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#no network 1.2.3.0/24 area 4.5.6.7
         The following example shows the OSPF router interface settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context router ospf default-information originate metric 1 metric-type 2 redistribute static metric-type 1 passive vlan1 route-limit num-routes 10 reset-time 10 ip default-gateway priority 1 nx9500-6C8809(config-profile default-ap8533-router-ospf)#
