Configures a minimum and maximum delay time in the initiation of the device adoption process. When configured, devices do not attempt adoption immediately on coming up. The process is initiated after the lapse of a specified period of time (configured using this command as the start-delay minimum time).
Once configured and applied, this setting is applicable on all devices using this profile. This option is also available in the device-configuration mode.
adoption start-delay min <0-30> max <0-30>
| adoption start-delay min <0-30> max <0-30> | Delays start of
 A device, on coming up, attempts adoption only after the lapse of the time specified here. The default is 5 seconds.
nx9500-6C8809(config-profile-test4K)#adoption start-delay min 10 max 30
         nx9500-6C8809(config-profile-test4K)#show context include-factory | include adoption enforce-version adoption strict controller adoption adoption start-delay min 10 max 30 adoption-mode controller nx9500-6C8809(config-profile-test4K)#
| no | Removes the configured minimum start-delay value. When removed, devices attempt adoption immediately on coming up. |
