ex3548
    Adds a EX3548 switch
      to the networkThe EX3548 series switch is a Gigabit Ethernet layer 2
        switch with either 24 or 48 10/100/1000-BASE-T ports, and four SFP
        transceiver slots for fiber connectivity.
    Supported in the
        following platforms:
        - Service Platforms —
          NX7500, NX9500, NX9600, VX9000
Syntax
      ex3548 <DEVICE-EX3548-MAC>
    Parameters
              | <DEVICE-EX3548-MAC> | Specifies the MAC address of a EX3548 switch |
      nx9500-6C8809(config)#ex3548 22-65-78-09-12-35
      nx9500-6C8809(config-device-22-65-78-09-12-35)#?
EX35xx Device Mode commands:
  hostname         Set system's network name
  interface        Select an interface to configure
  ip               Internet Protocol (IP)
  no               Negate a command or set its defaults
  power            EX3500 Power over Ethernet Command
  remove-override  Remove configuration item override from the device (so
                   profile value takes effect)
  upgrade          Configures upgrade option for ex3500 system
  use              Set setting to use
  clrscr           Clears the display screen
  commit           Commit all changes made in this session
  do               Run commands from Exec mode
  end              End current mode and change to EXEC mode
  exit             End current mode and down to previous mode
  help             Description of the interactive help system
  revert           Revert changes
  service          Service Commands
  show             Show running system information
  write            Write running configuration to memory or terminal
    Related Commands
              | no | Removes a EX3548 switch from the network |
