Removes or reverts the settings defined for a deny or permit route-map rule
no [description|match <PARAMETERS>|set <PARAMETERS>]
no <PARAMETERS>
| no <PARAMETERS> | Removes the description configured for a deny or permit route-map rule |
The following example shows the ‘deny route-map rule-1‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-dr-route-map-test-dr-route-map-rule-1)#show context deny route-map 1 description "This is a deny route map rule" match as-path FilterList_01 match ip-route-source prefix-list PrefixList_01 set aggregator-as 1 192.168.13.7 set as-path exclude 20 set ip next-hop peer-address set metric 300 set local-preference 30 set community internet nx9500-6C8809(config-dr-route-map-test-dr-route-map-rule-1)#
nx9500-6C8809(config-dr-route-map-test-dr-route-map-rule-1)#no match as-path
      nx9500-6C8809(config-dr-route-map-test-dr-route-map-rule-1)#no set aggregator-as
      nx9500-6C8809(config-dr-route-map-test-dr-route-map-rule-1)#no set metric
      nx9500-6C8809(config-dr-route-map-test-dr-route-map-rule-1)#show context deny route-map 1 description "This is a deny route map rule" match ip-route-source prefix-list PrefixList_01 set as-path exclude 20 set ip next-hop peer-address set local-preference 30 set community internet nx9500-6C8809(config-dr-route-map-test-dr-route-map-rule-1)#
nx9500-6C8809(config-dr-route-map-test)#show context route-map test deny route-map 1 description "This is a deny route map rule" match ip-route-source prefix-list PrefixList_01 set as-path exclude 20 set ip next-hop peer-address set local-preference 30 set community internet permit route-map 2 match ip-next-hop DL_01 nx9500-6C8809(config-dr-route-map-test)#
