ipv6
    Creates an IPv6 ACL and enters its
      configuration mode. An IPv6 ACL defines a set of rules that filter IPv6 packets flowing
      through a port or interface. Each rule specifies the action taken when a packet matches the
      rule. If the action is deny, the packet is dropped. If the action is permit, the packet is
      allowed.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      ipv6 access-list <IPv6-ACL-NAME>
    Parameters
              | access-list <IPv6-ACL-NAME> | Configures an IPv6 access list and enters its
                configuration mode
                  <IPv6-ACL-NAME> – Specify the IPv6 ACL name. If the access list does not
                    exist, it is created. |
      rfs4000-229D58(config)#ipv6 access-list IPv6ACLTest
rfs4000-229D58(config-ipv6-acl-IPv6ACLTest)#?
IPv6 Access Control Mode commands:
  deny     Specify packets to reject
  no       Negate a command or set its defaults
  permit   Specify packets to forward
  clrscr   Clears the display screen
  commit   Commit all changes made in this session
  do       Run commands from Exec mode
  end      End current mode and change to EXEC mode
  exit     End current mode and down to previous mode
  help     Description of the interactive help system
  revert   Revert changes
  service  Service Commands
  show     Show running system information
  write    Write running configuration to memory or terminal
    Related Commands
              | no | Removes an IPv6 access control list |
