Configures the MTU size for the manual session. The MTU is the size (in bytes) of the largest protocol data unit the layer can pass between tunnel peers in this session. A larger MTU means processing fewer packets for the same amount of data.
mtu <128-1460>
mtu <128-1460>
| mtu <128-1460> | Configures the MTU size for this manual session
nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#mtu 200
         nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#show context l2tpv3 manual-session test local-cookie size 8 200 300 local-ip-address 1.2.3.4 mtu 200 local-session-id 1 nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#
| no | Resets the MTU size for this manual session to default (1460 bytes) |
