memory
    Configures the EX3500‘s memory utilization rising (upper) and falling (lower) threshold values. Once
      configured, the system sends a notification when the memory utilization exceeds the specified
      rising limit or falls below the specified falling limit.By customizing an EX3500's memory and CPU utilization‘s upper and lower thresholds, you
        can avoid over utilization of the EX3500‘s processor capacity when
        sharing network resources with an NX series service platform or a WiNG VM.
        - Service Platforms — NX 95XX, NX 96XX, NX 7510
Syntax
      memory [falling-threshold|rising-threshold] <1-100>
    Parameters
              | memory | Configures the EX3500‘s memory utilization rising and
                falling threshold values. The system generates a notification when either of these
                limits is exceeded. |
              | falling-threshold <1-100> | Configures the falling threshold for the EX3500 memory
                utilization
                  <1-100> – Specify the
                    falling threshold as a percentage from 1 - 100. The default is 70%. |
              | rising-threshold <1-100> | Configures the rising threshold for the EX3500‘s
                memory utilization
                    rising threshold as a percentage from 1 - 100. The default is 90%. |
      nx9500-6C8809(config-ex3500-management-policy-test)#memory falling-threshold 50
      nx9500-6C8809(config-ex3500-management-policy-test)#memory rising-threshold 95
      nx9500-6C8809(config-ex3500-management-policy-test)#show context
ex3500-management-policy test
 http secure-server
 enable password level 3 7 12345678901020304050607080929291
 snmp-server notify-filter 1 remote 127.0.0.1
