Enables validation of the cross certificate using the factory certificate. When enabled, the obtained cross-certificate is validated against the operator‘s certificate configured on the device. An error message is displayed in case the cross-certificate is not obtained or if the cross-certificate is found to be invalid. This option is disabled by default.
To configure the operator certificate, in the device configuration mode execute the trustpoint > cmp-auth-operator command. For more information, see trustpoint (device-config-mode).cross-cert-validate
None
nx9500-6C8809(config-cmp-policy-test)#cross-cert-validate
      nx9500-6C8809(config-cmp-policy-test)#show context crypto-cmp-policy test cert-key-size 3072 cross-cert-validate ca-server primary host 192.168.8.74 port 8 path cmp nx9500-6C8809(config-cmp-policy-test)#
| no | Disables validation of the cross certificate with the factory certificate |
