eap-types
      Configures client access based on the
         EAP type used
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         eap-types [allow|deny] [aka|all|fast|peap|sim|tls|ttls] {(aka|all|fast|peap|sim|tls|ttls)}
      Parameters
                     | eap-types [allow|deny] | Configures a list of allowed or denied EAP types
                           allow – Configures a
                              list of EAP types allowed for WLAN client authenticationdeny – Configures a
                              list of EAP types not allowed for WLAN client authentication |
                     | [aka|all|fast|peap|sim| tls|ttls] | The following EAP types are common to the ‘allow‘ and ‘deny‘
                           keywords:
                           aka – Configures EAP
                                 Authentication and Key Agreement (AKA) and EAP-AKA‘ (AKA
                              Prime). EAP-AKA is one of the methods in the EAP authentication
                              framework. It uses Universal Mobile Telecommunications System
                              (UMTS) and Universal Subscriber Identity Module (USIM) for
                              client authentication and key distribution.all – Allows or denies
                              usage of all EAP types on the WLANfast – Configures EAP
                                 Flexible Authentication via Secure Tunneling (FAST).
                              EAP-FAST establishes a Transport Layer Security (TLS) tunnel,
                              to verify client credentials, using Protected Access Credentials
                              (PAC).peap – Configures
                                 Protected Extensible Authentication Protocol (PEAP). PEAP or
                              Protected EAP uses encrypted and authenticated TLS tunnel to
                              encapsulate EAP.sim – Configures EAP
                                 Subscriber Identity Module (SIM ). EAP-SIM uses Global
                                 System for Mobile Communications (GSMC) SIM for client
                              authentication and key distribution.tls – Configures EAP
                              TLS. EAP-TLS is an EAP authentication method that uses PKI to
                              communicate with a RADIUS server or any other authentication
                              server.ttls – Configures
                                 Tunneled Transport Layer Security (TTLS). EAP-TTLS is an
                              extension of TLS. Unlike TLS, TTLS does not require every client to
                              generate and install a CA- signed certificate.These options are
                              recursive, and more than one EAP type can be selected. The selected
                              options are added to the allowed or denied EAP types list. |
         nx9500-6C8809(config-wlan-test)#eap-types allow fast sim tls
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode tunnel
 encryption-type none
 authentication-type none
