no [custom-scan|rss1-interval-duration|scan-mode]
no custom-scan channel-frequency <CHANNEL-FREQUENCY-LIST>
no rssi-interval-duration
no scan-mode
no <PARAMETERS>
| no <PARAMETERS> | Removes or reverts to default a sensor policy settings based on the parameters passed |
The following example shows the sensor-policy ‘test‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809nx9500-6C8809(config-sensor-policy-test)#show context sensor-policy test rssi-interval-duration 30 scan-mode Custom-Scan custom-scan channel-frequency 2412 width 20MHz scan-weight 1000 custom-scan channel-frequency 2417 width 20MHz scan-weight 1000 nx9500-6C8809(config-sensor-policy-test)#
The scan-mode is reverted back to the default setting of 'Default-Scan', as show in the following output:
nx9500-6C8809(config-sensor-policy-test)#no scan-mode
      nx9500-6C8809(config-sensor-policy-test)#no custom-scan channel-frequency 2412
      nx9500-6C8809(config-sensor-policy-test)#no custom-scan channel-frequency 2417
      nx9500-6C8809(config-sensor-policy-test)#show context sensor-policy test rssi-interval-duration 30 scan-mode Default-Scan nx9500-6C8809(config-sensor-policy-test)#
