The Smart RF sensitivity level options include low, medium, high, and custom. The custom option allows you to adjust the parameters and thresholds for interference recovery, coverage hole recovery, and neighbor recovery. However, the low, medium, and high settings still allow utilization of these features.
sensitivity [custom|high|low|medium]
| sensitivity | Configures Smart RF sensitivity levels. The options available are: custom, high, low, and medium. |
| custom | Enables custom interference recovery, coverage hole recovery, and neighbor recovery as additional Smart RF options |
| high | High sensitivity |
| low | Low sensitivity |
| medium | Medium sensitivity. This is the default setting. |
To enable the power and channel setting parameters, set sensitivity to custom or medium.
To enable the monitoring and scanning parameters, set sensitivity to custom.
To enable the neighbor recovery, interference and coverage hole recovery parameters, set sensitivity to custom.
nx9500-6C8809(config-smart-rf-policy-test)#sensitivity high
         nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test area test channel-list 2.4GHz 1,2,3 group-by floor sensitivity high channel-list 2.4GHz 1,12 channel-width 5GHz auto smart-ocs-monitoring frequency 5GHz 3 smart-ocs-monitoring frequency 2.4GHz 3 smart-ocs-monitoring sample-count 5GHz 3 smart-ocs-monitoring sample-count 2.4GHz 3 --More-- nx9500-6C8809(config-smart-rf-policy-test)#
