Removes or modifies the Bonjour Gateway Discovery policy settings
no allow-service <BONJOUR-SERVICE-NAME> [local|tunneled] {service-vlans <WORD>}
      | no <parameters> | Removes allow-service rules in the selected Bonjour GW Discovery policy, based on the parameters passed |
The following example shows the Bonjour GW Discovery policy ‘test‘ settings before the ‘no‘ command is executed:
nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#show context bonjour-gw-discovery-policy test allow-service Printer local service-vlans 1-2 instance-name contains $Bonjour_Service allow-service Afp local nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#
nx9500-6C8809(config-bonjour-gw-discovery-policy-test1)#no allow-service Afp local
      The following example shows the Bonjour GW Discovery policy ‘test‘ settings after the ‘no‘ command was executed:
nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#show context bonjour-gw-discovery-policy test allow-service Printer local service-vlans 1-2 instance-name contains $Bonjour_Service nx9500-6C8809(config-bonjour-gw-discovery-policy-test)#
