radius [dynamic-authorization|nas-identifier|nas-port-id|vlan-assignment]
radius [dynamic-authorization|nas-identifier <NAS-ID>|nas-port-id <NAS-PORT-ID>| vlan-assignment]
| dynamic-authorization | Enables support for disconnect and change of authorization messages (RFC5176). When enabled, this option extends the RADIUS protocol to support unsolicited messages from the RADIUS server. These messages allow administrators to issue change of authorization (CoA) messages, which affect session authorization, or disconnect messages (DM) that terminate a session immediately. This option is disabled by default. |
| nas-identifier <NAS-ID> | Configures the network access server (NAS) identifier attribute,
                        a value that identifies the access point or controller where the RADIUS
                        messages originate. The value specified here is included in the RADIUS
                        NAS-Identifier field for WLAN authentication and accounting packets.
| nas-port-id <NAS-PORT-ID> | Configures the WLAN NAS port ID sent to the RADIUS server. The NAS port
                        identifier should not exceed 256 characters.
 The profile database on the RADIUS server consists of user profiles for each connected NAS port. Each profile is matched to a username representing a physical port. When authorizing users, it queries the user profile database using a username representative of the physical NAS port making the connection. Set the numeric port value from 0 - 4294967295. |
| vlan-assignment | Configures the VLAN assignment of a WLAN. RADIUS VLAN assignment is
                        disabled by default. When enabled, this option assigns clients to the RADIUS server specified VLANs, overriding the WLAN configuration. This option is disabled by default. If, as part of the authentication process, the RADIUS server returns a client's VLAN-ID in a RADIUS access-accept packet, and this feature is enabled, all client traffic is forwarded on that VLAN. If disabled, the RADIUS server returned VLAN-ID is ignored and the VLAN specified using the vlan/vlan-pool-member options (in the WLAN config mode) is used. If both the RADIUS VLAN assignment and the post authentication VLAN options are enabled, then RADIUS VLAN assignment takes priority over post authentication VLAN configuration. |
nx9500-6C8809(config-wlan-test)#radius vlan-assignment
         nx9500-6C8809(config-wlan-test)#show context wlan test ssid test bridging-mode local encryption-type none authentication-type none protected-mgmt-frames mandatory radius vlan-assignment wing-extensions wmm-load-information client-load-balancing probe-req-intvl 5ghz 5 client-load-balancing band-discovery-intvl 2 --More-- nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Disables support for disconnect and change of authorization messages. Disables the use of VLAN information received in RADIUS server responses, instead uses the VLAN provided in the WLAN configuration. Removes the NAS identifier and NAS port identifiers configured. |
