Defines an action based on conflicts detected in a device‘s IPv6 and MAC addresses
ipv6-mac [conflict|routing]
ipv6-mac conflict [drop-only|log-and-drop|log-only]
ipv6-mac routing conflict [drop-only|log-and-drop|log-only]
| conflict | Enables detection of conflict between a device‘s IPv6
                and MAC addresses. This option is enabled by default. This command also specifies the action to be performed when a such a conflict is detected. The options are: drop-only, log-and-drop, and log-only. |
| drop-only | Drops a packet (with conflicting IPv6 and MAC address) without logging |
| log-and-drop | Logs the event and drops the packet. This is the default setting. |
| log-only | Logs the event only, the packet is not dropped |
| log-level | If selecting the “log-and-drop” and “log-only” action
                type, specify the log level. The options are:
| routing conflict | Enables detection of conflict between the next-hop‘s IPv6 and MAC addresses.
| drop-only | Drops a packet (with conflicting next-hop IPv6 and MAC addresses) without logging |
nx9500-6C8809(config-fw-policy-testFW)#ipv6-mac routing conflict drop-only
      nx9500-6C8809(config-fw-policy-testFW)#show context firewall-policy testFW ip dos fraggle drop-only ip dos tcp-sequence-past-window drop-only ip dos tcp-max-incomplete high 600 ip dos tcp-max-incomplete low 60 ip-mac conflict drop-only ip-mac routing conflict log-and-drop log-level notifications flow timeout icmp 16000 flow timeout udp 10000 flow timeout tcp established 1500 flow timeout other 16000 dhcp-offer-convert ipv6 routing-type two log-and-drop log-level warnings ipv6 dos hop-limit-zero drop-only alg facetime dns-snoop entry-timeout 1200 ipv6-mac routing conflict drop-only nx9500-6C8809(config-fw-policy-testFW)#
| no | Disables actions based on IPv6 and MAC address conflict detection |
