use [ble-data-export-policy|database-policy|license|nsight-policy|
rtl-server-policy|sensor-policy|smart-rf-policy|wips-policy]
         use [ble-data-export-policy <POLICY-NAME>|database-policy <DATABASE-POLICY-NAME>| license <WEB-FILTERING-LICENSE>|nsight-policy <NSIGHT-POLICY-NAME>| rtl-server-policy <RTL-SERVER-POLICY-NAME>|sensor-policy <SENSOR-POLICY-NAME>| smart-rf-policy <SMART-RF-POLICY-NAME>|wips-policy <WIPS-POLICY-NAME>]
         | use | Associates the following policies with the RF Domain: ble data export policy, database policy, NSight policy, sensor policy, Smart RF policy, WIPS policy. It also applies a Web filtering license to the selected RF Domain. |
| ble-data-export-policy <POLICY-NAME> | Associates a BLE data export policy with this RF Domain
| database-policy <DATABASE-POLICY-NAME> | Associates a database policy with the selected RF
                           Domain
 Note:
                            This feature is not supported on the AP5XX model access points. |
| license <WEB-FILTERING-LICENSE> | Obtains the specified Web filtering license from the adopting
                           controller
| nsight-policy <NSIGHT-POLICY-NAME> | Associates an NSight policy with the selected RF Domain
| rtl-server-policy <RTL-SERVER-POLICY-NAME> | Associates an Real
                           Time Locationing (RTL) server policy with the selected RF
                           Domain
| sensor-policy <SENSOR-POLICY-NAME> | Associates a sensor policy with the selected RF Domain
| smart-rf-policy <SMART-RF-POLICY-NAME> | Associates a Smart RF policy with the selected RF Domain. When
                        associated, the Smart RF policy provides automatic recovery from coverage
                        loss (due to failed or faulty radio) by instructing neighboring access
                        points to increase their transmit power. Once correct access point placement has been established, Smart-RF can optionally be leveraged for automatic detector radio selection. Smart-RF uses detector radios to monitor RF events to ensure availability of adequate detector coverage.
 Note: SMART RF is only applicable on AP510i/e and AP560i/h functioning
                           in the dual-5GHz mode. That is, on the AP, RF mode for both radios is set
                           to WLAN-5GHz. |
| wips-policy <WIPS-POLICY-NAME> | Associates a WIPS policy with the selected RF Domain. A WIPS policy
                        provides protection against wireless threats and acts as a key layer of
                        security complementing wireless VPNs, encryption and authentication. A WIPS
                        policy uses a dedicated sensor for actively detecting and locating rogue AP
                        devices. After detection, WIPS uses mitigation techniques to block the
                        devices by manual termination, air lockdown, or port suppression.
nx9500-6C8809(config-rf-domain-default)#use smart-rf-policy Smart-RF1
         nx9500-6C8809(config-rf-domain-default)#use wips-policy WIPS1
         nx9500-6C8809(config-rf-domain-default)#show context rf-domain default contact Bob+14082778691 timezone America/Los_Angeles stats update-interval 200 country-code us use smart-rf-policy Smart-RF1 use wips-policy WIPS1 sensor-server 2 ip 172.16.10.3 override-smartrf channel-list 2.4GHz 1,2,3 override-wlan test vlan-pool 2 limit 20 layout area Ecospace floor Floor1 map-location www.firstfloor.com units meters nx9500-6C8809(config-rf-domain-default)#
| no (rf-domain-config-mode) | Removes policies associated with this RF Domain |
