username
    Configures a vEX3500 switch user settingsThe EX3500 switch user details
        are stored in a local database on the NX 95XX, NX 96XX, NX 7510, or WiNG VM. You
        can configure multiple users, each having a unique name, access level, and
      password.
        - Service Platforms — NX 95XX, NX 96XX, NX 7510
Syntax
      username <USER-NAME> [access-level <0-15>|nopassword|password [0|7] <PASSWORD>]
    Parameters
              | username <USER-NAME> | Configures the TACACS server port username
                  <USER-NAME> – Specify the user name (should not exceed 32 characters) |
              | access-level <0-15> | Configures the access level for this user. This value determines the access
                priority of each user requesting access and interoperability with EX3500 switch.
                  <0-15> – Specify the
                    access level from 0 - 15. The default is 0. |
              | nopassword | Allows user to login without a password |
              | password [0|7] <PASSWORD> | Configures the password for this user
                  0 – Configures a plain text password 7 – Configures an encrypted password (should be 32 characters in length)
                      <PASSWORD> – Specify the password. |
      nx9500-6C8809(config-ex3500-management-policy-test)#username user1 access-level 5
      nx9500-6C8809(config-ex3500-management-policy-test)#username user1 password 0 user1@1234
      nx9500-6C8809(config-ex3500-management-policy-test)#show context
ex3500-management-policy test
 ssh server
 ssh authentication-retries 4
 ssh timeout 90
 ssh server-key size 600
 http secure-server
 enable password level 3 7 12345678901020304050607080929291
 username user1 password 7 5c4786c1e52f913d38168ce89154a079
 snmp-server enable traps authentication
 snmp-server notify-filter 3 remote 1.2.3.4
 snmp-server notify-filter 1 remote 127.0.0.1
--More--
