description
      Configures a description for this WLAN
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         description <LINE>
      Parameters
         description <LINE>
                     | <LINE> | Specify a description for this WLAN The WLAN‘s description should help
                           differentiate it from others with similar configurations. The description
                           should not exceed 64 characters. |
         nx9500-6C8809(config-wlan-test)#description TestWLAN
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode local
 encryption-type none
 uthentication-type eap
 accounting syslog host 172.16.10.4 port 2
 data-rates 2.4GHz gn
 client-load-balancing probe-req-intvl 5ghz 5
 client-load-balancing band-discovery-intvl 2
 captive-portal-enforcement fall-back
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
 broadcast-dhcp validate-offer
