no [deny|disable|permit]
no [deny|permit] [<SOURCE-MAC> <SOURCE-MAC-MASK>|any|host <SOURCE-HOST-MAC>]
[<DEST-MAC> <DEST-MAC-MASK>|any|host <DEST-HOST-MAC>] (dot1p <0-7>,type [8021q|<1-65535>|
aarp|appletalk|arp|ip|ipv6|ipx|mint|rarp|wisp],vlan <1-4095>) log (rule-precedence <1-5000>)
{(rule-description <LINE>)}
         no disable [deny|permit] <RULE-PARAMETERS>
         | no [deny|permit] | Removes a deny or permit rule from the MAC ACL |
| <SOURCE-MAC> <SOURCE-MAC-MASK> | Specify the source MAC address and mask |
| any | Select ‘any‘ if the rule is applicable to any source MAC address |
| host <SOURCE-HOST-MAC> | Specify the source host‘s exact MAC address. |
| <DEST-MAC> <DEST-MAC-MASK> | Specify the destination MAC address and mask |
| any | Identifies all devices as the destination to deny/permit access |
| host <DEST-HOST-MAC> | Specify the destination host‘s exact MAC address. |
| dotp1p <0-7> | Specify the 802.1p priority value from 0 -7. |
| type [8021q|<1-65535>| aarp|appletalk|arp|ip|ipv6|ipx|mint|rarp|wisp] | Specify the EtherType value. |
| vlan <1-4095> | Specify the VLAN ID. |
| log | Select log, if the rule has been configured to log records in case of a match. |
| mark [8021p <0-7>| dscp <0-63>] | This is specific to the MAC ACL permit rule. Marks packets that match the ACL rule 8021p <0-7> – Modifies 802.1p VLAN user priority from 0 - 7 dscp <0-63> – Modifies DSCP TOS bits in the IP header from 0 - 63 |
| rule-precedence <1-5000> | Specify the rule precedence. The rule with the specified rule precedence is removed from the MAC ACL. |
| rule-description <LINE> | Optional. Provide the description configured for the rule. |
| no disable [deny|permit] | Removes a disabled deny or permit rule from the selected IP access list |
| <RULE-PARAMETERS> | Enter the exact parameters used when configuring the rule. |
| rule-precedence <1-5000> rule-description <LINE>} | Specify the precedence assigned to this disabled deny/permit rule.
 Note: The system removes the disabled rule from the selected ACL. |
nx9500-6C8809(config-mac-acl-test)#show context
mac access-list test
 permit host 11-22-33-44-55-66 any log mark 8021p 3 rule-precedence 600
 permit host 22-33-44-55-66-77 host 11-22-33-44-55-66 type ip log rule-precedence 610
 deny any host 33-44-55-66-77-88 log rule-precedence 700
         nx9500-6C8809(config-mac-acl-test)#no deny any host 33-44-55-66-77-88 log rule-precedence 700
