area <AREA-NAME/STRING-ALIAS> [assignable-power|channel-list]
         area <AREA-NAME/STRING-ALIAS> assignable-power [2.4GHz|5GHz|6GHz] [min|max] <1-20>
area <AREA-NAME/STRING-ALIAS> channel-list [2.4GHz|5GHz|6GHz] <CHANNEL-LIST>
| area <AREA-NAME/STRING-ALIAS> | Specifies the area name
 Note: For more
                           information on aliases, see alias. |
| assignable-power [2.4GHz|5GHz|6GHz] | Assigns minimum and maximum transmit power values, in
                        dBm, to the 2.4 GHz, 5 GHz, and 6GHz Smart RF managed radios within the
                        specified area. The per-area transmit power values override the generic
                        transmit power values configured in the Smart-RF policy assignable-power. Select the band:After selecting the area and band specify the minimum and
                        maximum transmit power values:
| min <1-20> | After selecting the band specify the minimum assignable
                        transmit power
| max <1-20> | After selecting the band specify the maximum assignable
                        transmit power
 Note: As a best
                           practice, we recommend not to increase the maximum power values for the
                           2.4 GHz or 5 GHz radios beyond the default 17 dBm, which provides a 3 dBm
                           margin for the Neighbor Recovery and Coverage Hole Recovery features. If
                           each radio in the system is operating at a maximum of 20 dBm, the Smart
                           RF managed radios will be unable to increase their transmit power if a
                           neighboring AP fails or a coverage hole is detected. Increase the maximum
                           power value only if the Neighbor Recovery and Coverage Hole Recovery
                           features are disabled. |
 Note: For more
| channel-list [2.4GHz|5GHZ|6GHZ] <CHANNEL-LIST> | Selects the channels for the specified area in the 2.4
                        GHz, 5.0 GHz, or 6.0 GHz band
nx9500-6C8809(config-smart-rf-policy-test)#area test1 assignable-power 2.4GHz min 10 max 15
nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test area test1 assignable-power 2.4GHz min 10 max 15 no select-shutdown nx9500-6C8809(config-smart-rf-policy-test)#
nx9500-6C8809(config)#alias string $AREA Ecospace nx9500-6C8809(config)#commit nx9500-6C8809(config-smart-rf-policy-test)#exit
nx9500-6C8809(config-smart-rf-policy-Ecospace)#area $AREA channel-list 5GHz 36,44
         nx9500-6C8809(config-smart-rf-policy-Ecospace)#show context smart-rf-policy Ecospace area $AREA channel-list 5GHz 36,44 nx9500-6C8809(config-smart-rf-policy-Ecospace)#
| no (smart-rf-policy-config-mode-command) | Removes channel list/power configuration for an area |
