crypto-map-ipsec-manual-instance
Removes or resets this crypto map‘s settings
no [local-endpoint-ip|mode|peer|security-association|session-key|use]
no <PARAMETERS>
| no <PARAMETERS> | Removes or resets this crypto map settings based on the parameters passed |
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#show context crypto map map1 1 ipsec-manual use ip-access-list test peer 172.16.10.12 mode transport session-key inbound esp 273 0 cipher esp-null authenticator sha 5876897 nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)# nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#no use ip-access-list nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#no peer nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#no mode nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#show context crypto map map1 1 ipsec-manual session-key inbound esp 273 0 cipher esp-null authenticator sha 58768979 nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#
