wlan-qos-policy
      Configures a WLAN QoS policy and
         enters its configuration mode
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         wlan-qos-policy <WLAN-QOS-POLICY-NAME>
      Parameters
                     | <WLAN-QOS-POLICY-NAME> | Specify the WLAN QoS policy name. If a policy with the specified name
                        does not exist, it is created. |
         nx9500-6C8809(config)#wlan-qos-policy test
nx9500-6C8809(config-wlan-qos-test)#?
WLAN QoS Mode commands:
  accelerated-multicast  Configure accelerated multicast streams address and
                         forwarding QoS classification
  classification         Select how traffic on this WLAN must be classified
                         (relative prioritization on the radio)
  multicast-mask         Egress multicast mask (frames that match bypass the
                         PSPqueue. This permits intercom mode operation
                         without delay even in the presence of PSP clients)
  no                     Negate a command or set its defaults
  qos                    Quality of service
  rate-limit             Configure traffic rate-limiting parameters on a
                         per-wlan/per-client basis
  svp-prioritization     Enable spectralink voice protocol support on this
                         wlan
  voice-prioritization   Prioritize voice client over other client (for
                         non-WMM clients)
  wmm                    Configure 802.11e/Wireless MultiMedia parameters
  clrscr                 Clears the display screen
  commit                 Commit all changes made in this session
  do                     Run commands from Exec mode
  end                    End current mode and change to EXEC mode
  exit                   End current mode and down to previous mode
  help                   Description of the interactive help system
  revert                 Revert changes
  service                Service Commands
  show                   Show running system information
  write                  Write running configuration to memory or terminal
      Related Commands
                     | no | Removes an existing WLAN QoS POLICY |
For more information on WLAN QoS
            policy commands, see
WLAN-QoS Policy.
