no [channel|enable|fcc-mode|output-power|payload-size|port|server|ssl|window-size]
    no <PARAMETERS>
| no <PARAMETERS> | Reverts this IoT Device-Type Imagotag policy settings to default value |
The following example shows the Imagotag policy settings before the no commands are executed:
NOC-NX9500(config-iot-device-type-imagotag-policy-test)#no ? iot-device-type-imagotag-policy test enable output-power Level-B window-size 12 payload-size 25 ssl fcc-mode channel 9 server ip-address 10.234.160.225 NOC-NX9500(config-iot-device-type-imagotag-policy-test)#
NOC-NX9500(config-iot-device-type-imagotag-policy-test)#no payload-size
NOC-NX9500(config-iot-device-type-imagotag-policy-test)#no window-size
NOC-NX9500(config-iot-device-type-imagotag-policy-test)#no server
The following example shows the Imagotag policy settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-iot-device-type-imagotag-policy-test)#show context iot-device-type-imagotag-policy test enable output-power Level-B ssl-enable fcc-enable channel 9 nx9500-6C8809(config-iot-device-type-imagotag-policy-test)#
