radius-group
         Configures RADIUS user group and enters its configuration mode
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         radius-group <RADIUS-GROUP-NAME>
      Parameters
                     | <RADIUS-GROUP-NAME> | Specify a RADIUS user group name. The name should not exceed 64
                        characters. If a RADIUS user group with the specified name does not exist,
                        it is created. |
         nx9500-6C8809(config)#radius-group testRadiusGr
nx9500-6C8809(config-radius-group-testRadiusGr)#?
Radius user group configuration commands:
  guest       Make this group a Guest group
  no          Negate a command or set its defaults
  policy      Radius group access policy configuration
  rate-limit  Set rate limit for group
  clrscr      Clears the display screen
  commit      Commit all changes made in this session
  do          Run commands from Exec mode
  end         End current mode and change to EXEC mode
  exit        End current mode and down to previous mode
  help        Description of the interactive help system
  revert      Revert changes
  service     Service Commands
  show        Show running system information
  write       Write running configuration to memory or terminal
      Related Commands
                     | no | Removes an existing RADIUS group |
For more information on RADIUS user
            group commands, see
RADIUS Policy.
