area-type
      Configures a particular OSPF area as
         STUB, Totally STUB, NSSA or Totally NSSA. Areas can defined as:
            - stub area - Is an area that does not
               receive route advertisements external to the AS (autonomous system), and
               routing from within the area is based entirely on a default route.
- totally-stub - Is an area that does
               not allow summary routes and external routes. A default route is the only way to
               route traffic outside of the area. When there is only one route out of the area,
               fewer routing decisions are needed, lowering system resource utilization.
- non-stub - Is an area that imports
               autonomous system external routes and forwards to other areas. However. it still
               cannot receive external routes from other areas.
- nssa - A NSSA (Not-So-Stubby
                  Area) is an extension of a stub that allows the injection of limited external
               routes into a stub area. If selecting NSSA, no external routes, except a default
               route, enter the area.
- totally nssa - Is a NSSA using 3 and
               4 summary routes are not flooded into this type of area. It is also possible to
               declare an area both totally stubby and not-so-stubby, which means that the area will
               receive only the default route from area 0.0.0.0, but can also contain an ASBR
                  (Autonomous System Boundary Router) that accepts external routing
               information and injects it into the local area, and from the local area into area
               0.0.0.0.
            - Access Points — AP410i/e, AP460i/e,
               AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
               AP8533
Syntax
         area-type [nssa|stub]
         area-type nssa {default-cost|no-summary|translate-always|translate-candidate|
translate-never}
         area-type nssa {default-cost <0-16777215> {no-summary}|no-summary
{default-cost <0-16777215>}}
         area-type nssa {translate-always|translate-candidate|translate-never}
{(default-cost <0-16777215>|no-summary)}
         area-type stub {default-cost <0-16777215> {no-summary}|no-summary
      Parameters
translate-never}
                     | area-type | Configures a particular OSPF area type as STUB, Totally STUB, NSSA or
                        Totally NSSA |
                     | nssa | Configures the OSPF area as NSSA |
                     | stub | Configures the OSPF area as STUB Stubby Area |
                     | default-cost <0-16777215> | Specifies the default summary cost advertised, if the OSPF area is a
                        STUB or NSSA
                           <0-16777215> –
                              Specify the default summary cost value from 0 - 16777215. |
                     | no-summary | Configures the OSPF area as totally STUB if the area-type is STUB or
                        totally NSSA if the area-type is NSSA |
                     | translate-always | Always translates type-7 LSAs (Link State Advertisements) into
                        type-5 LSAs |
                     | translate-candidate | Defines it as default behavior |
                     | translate-never | Never translates type-7 LSAs into type-5 LSAs |
         nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#area-type stub default-cost 1
         nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#show context
  area 0.0.0.1
