In a typical WLAN, getting the right balance between the number of APs functioning as sensors and APs providing WLAN service is a serious challenge. The challenge increases exponentially with increase in the size of the deployment. As a rule, approximately 1/3 of the APs within a site should be configured as sensors to provide adequate coverage and monitor WLAN activity. Determining the minimum number of sensor APs required, selecting the APs ideally located to work as sensors and provisioning them as sensors is a cumbersome process. The Smart-sensor feature automates this process using an algorithm.
In a Smart-RF monitored deployment, neighbor details and configuration updates are collected in the Smart-RF neighbor table. This information is used in the algorithm to create a cluster of cells, with each cell representing an AP. The algorithm then identifies APs with best coverage area and provisions them as sensors. The algorithmic calculations vary depending on the cell size. The current implementation provides two algorithms based on whether the AP deployment is dense (small cell size) or sparse (big cell size).
Tri-radio APs will operate as dedicated sensors, where as dual-radio APs will operate in the radio-share mode.A new 'tri-radio-only' parameter has been added for deployments consisting of tri-radio and dual-radio APs. This parameter, by default, provisions only tri-radio APs as sensors. Refer to the table for more information.
smart-sensor {algorithm|auto-trigger|band|tri-radio-only}
            smart-sensor algorithm cell-size [dense|sparse]
smart-sensor {auto-trigger}
            smart-sensor {band [smart-band-24GHz|smart-band-5GHz|smart-band-6GHz]}
            smart-sensor tri-radio-only
| smart-sensor | Enables the Smart-sensor feature and configures the required parameters |
| algorithm | Uses an algorithm to calibrate a cluster of cells and identify APs best suited to be provisioned as sensors. |
| cell-size [dense|sparse] | Selects the algorithm to use based on the cell size. The options
                                    are:
 Note: By default
                                    none of the algorithmic options is selected. |
smart-sensor {auto-trigger|band [smart-band-24GHz|smart-band-5GHz|smart-band-6GHz]}
| auto-trigger | Optional. Enables/disables auto-triggering of smart-sensor
                                calibration. Note: The auto-trigger option is enabled by default.
                                    To disable auto-trigger, use the  no >
                                        smart-sensor > auto-triggercommand.The Smart-sensor feature uses an algorithmic function to identify APs best suited to be provisioned as sensors. This algorithmic function is auto-triggered when the Smart-sensor feature is enabled for the first time. Auto-triggering of calibration is a one-time
                                    process. In case, post auto-provisioning of the APs as sensor,
                                    the number of APs deployed has changed or if the AP deployment
                                    pattern has changed a re-calibration maybe need. To initiate
                                    re-calibration, you will have to manually issue the  |
| band [smart-band-24GHz|smart-band-5GHz|smart-band-6GHz] | Optional. Selects the band (2.4GHz/ 5GHz/ 6GHz) used for neighbor
                                list selection for the Smart-sensor feature.
 Note: Starting
                                    with WiNG 7.3.1, a  tri-radio-onlycommand has been introduced to
                                    enable selection of both tri-radio and dual-radio APs as
                                    sensors. See the following table for more
                                information. |
| tri-radio-only | This option restricts the Smart-sensor algorithm to
                                    only
                                select and provision tri-radio
                                    APs as sensors. Note: It is enabled by
                                    default. If your deployment consists of a mix of
                                    tri-radio and dual-radio APs, execute the  |
nx9500-6C8809(config)#smart-rf-policy smt-sensor
nx9500-6C8809(config-smart-rf-policy-smt-sensor)#smart-sensor
nx9500-6C8809(config-smart-rf-policy-test)#smart-sensor band smart-band-24GHz
nx9500-6C8809(config-smart-rf-policy-smt-sensor)#smart-sensor algorithm cell-size [dense|sparse]
Select 'dense' if the cell size is small (distance between neighboring APs is small). Select 'sparse' if the cell size if large (distance between neighboring APs is large).nx9500-6C8809(config-smart-rf-policy-smt-sensor)#show context smart-rf-policy smt-sensor no select-shutdown smart-sensor smart-sensor algorithm cell-size sparse smart-sensor auto-trigger smart-sensor band smart-band-24GHz smart-sensor tri-radio-only nx9500-6C8809(config-smart-rf-policy-smt-sensor)#
The auto-trigger and tri-radio-only options are enabled by default.nx9500-6C8809(config-smart-rf-policy-smt-sensor)#no smart-sensor tri-radio-only
nx9500-6C8809(config-rf-domain-smt-sensor)#use smart-rf-policy smt-sensor
| no (smart-rf-policy-config-mode-command) | Disables the smart-sensor feature |
