wep128
      Configures WEP128 parameters
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         wep128 [key|keys-from-passkey|transmit-key]
         wep128 key <1-4> [ascii|hex] [0 <WORD>|2 <WORD>|<WORD>]
         wep128 keys-from-passkey <WORD>
         wep128 transmit-key <1-4>
      Parameters
                     | wep128 | Configures WEP128 parameters. The parameters are: key, key-from-passkey,
                        and transmit-key. |
                     | key <1-4> | Use to configure the key number
                           <1-4> – Specify
                              the key number from 1 - 4. |
                     | ascii [0 <WORD>| 2 <WORD>|<WORD>] | Sets keys as ASCII characters (5 characters for WEP64, 13 for WEP128)
                           0 <WORD> –
                              Configures a clear text key2 <WORD> –
                              Configures an encrypted key<WORD> –
                              Configures keys as 13 ASCII characters converted to hex, or 26
                              hexadecimal characters |
                     | hex [0 <WORD>| 2 <WORD>|<WORD>] | Sets keys as hexadecimal characters (10 characters for WEP64, 26 for
                           WEP128)
                           0 <WORD> –
                     | keys-from-passkey <WORD> | Specifies a pass key. The pass key can be any alphanumeric string.
                        Controllers, service platforms, Access Points and their connected clients
                        use the algorithm to convert an ASCII string to the same hexadecimal number.
                        Clients without adapters need to use WEP keys manually configured as
                        hexadecimal numbers.
                           <WORD> – Specify
                              a pass key from 4 - 32 characters. |
                     | transmit-key <1-4> | Configures the key index used for transmission from an AP to a wireless
                        client or service platform
                           <1-4> – Specify
                              a key index from 1 - 4. |
         NOC-NX9500(config-wlan-test)#wep128 key 1 ascii 123456789abcd
         NOC-NX9500(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode local
 encryption-type none
 authentication-type none
 wep128 key 1 hex 0 31323334353637383961626364
