aaa authentication
Configures the Authentication, Accounting, and Authorization (AAA) log-in sequence.
Syntax
aaa authentication login { default | ldap | local | oauth2 | radius | tacacs+ } [ { local | local-auth-fallback | ldap-auth-fallback | oauth2-auth-fallback | radius-auth-fallback | tacacs+-auth-fallback } [ local-auth-fallback ] ]
no aaa authentication login
Command Default
The default server is Local.
Parameters
login
Specifies the type of server that will be used for AAA on the device. The local server is the default. Specify one of the following options.
default
Specifies the default mode (local server). Authenticates the user against the local database only. If the password does not match or the user is not defined, the login fails.
ldap
Specifies the Lightweight Directory Access Protocol (LDAP) servers.
local
Specifies the local device database if previous authentication methods are inactive.
oauth2
Specifies the OAuth2 token.
radius
Specifies the RADIUS servers.
tacacs+
Specifies the TACACS+ servers.
ldap-auth-fallback
Specifies that LDAP authentication be used if the previous authentication methods are not active or the authentication attempt fails. This is an optional parameter.
Specifies that OAuth2 authentication be used if the previous authentication methods are not active or the authentication attempt fails. This is an optional parameter.
Specifies that RADIUS authentication be used if the previous authentication methods are not active or the authentication attempt fails. This is an optional parameter.
Specifies that TACACS+ authentication be used if the previous authentication methods are not active or the authentication attempt fails. This is an optional parameter.
local-auth-fallback
Specifies the local device database if previous authentication methods are not active or if authentication fails. This is an optional parameter.
Modes
Global configuration mode
Usage Guidelines
This command selects the order of authentication sources to be used for user authentication during the login process. Three sources of authentication are supported, primary, secondary, and tertiary. The secondary and tertiary authentication sources are optional. They are only used if they are configured and the preceding authentication source fails or is not reachable.
Configuring secondary source of authentication is optional. Configuring tertiary source is also optional, however, it can only be configured when a secondary source is also configured.
Fallback to the next authentication source will only happen if the previous authentication server is not available or not reachable. Fallback will not happen if the previous authentication server is available to authenticate and if wrong credentials are passed to it or if the server rejects the parameters passed to it for other reasons.
Caution
Caution
SSH imposes an immutable timeout of 120 seconds. Administrators should be aware that all authentication must complete within this time period.
It is recommended that retries and timeouts for the authentication servers be configured in a way that the authentication process (including fallback) completes within SSH's timeout value of 120 seconds.
For example, let us assume that there are five (5) servers configured for the primary authentication and five (5) servers for the secondary authentication. While authentication happens, connection will be tried to first primary server for the configured retry attempts for that server. If the server is unreachable, the next server in the list will be tried for the configured retry attempts. This process will be repeated till, either, one of the servers respond or all servers timeout. During this process of testing the various servers, there is a possibility that the SSH's timeout value is exceeded. Due to this, fallback to the next authentication method might not happen and your authentication may fail.
Authentication modes can only be set and cannot be added or deleted. For example, to change a configuration from radius local to radius only, execute the no aaa authentication login command to resets the configuration to the default mode, and then reconfigure the AAA mode with the desired setting.
Similarly, in a configuration with primary and secondary sources of authentication, the primary mode cannot be modified alone. For example, you cannot change from radius local or radius ldap-auth-fallback local-auth-fallback to tacacs+ radius-auth-fallback or tacacs+ local local-auth-fallback respectively. First remove the existing configuration and then configure it to the required configuration.
However, in a configuration where the primary and secondary sources of authentication are configured, it is possible to change the secondary source without using the no aaa authentication login command. For example, if you want to change the existing configuration from radius tacacs+ to radius ldap, then issue the command aaa authentication login radius ldap directly.
With OAuth2 authentication, the log-in request from the north-bound interface uses the OAuth2 token as a password. The device authenticates the user based on the validity of the OAuth2 token.
Also, for OAuth2 authentication only, both the local and local-auth-fallback options allow fallback to the local database if the secondary source of authentication is configured as local or local-auth-fallback. In this scenario, they behave in the same manner.
If login fails through the primary source because none of the configured servers respond or the login is rejected by the server, authentication is done again through the secondary source or local option. If the authentication using the secondary source also fails, then local-auth-fallback is used if configured.
When “local-auth-fallback” option is specified as the tertiary option, local authentication is tried only when the primary and the secondary AAA authentication service are either “unreachable” or “not available”. Unlike the “local” option, local authentication is not be attempted if the authentication with primary or secondary service fails.
Use the no form of the command to restore the authentication mode to local mode.
This example changes the AAA server to TACACS+ using the local device database as a secondary source of authentication.
device# configure terminal
device(config)# aaa authentication login tacacs+ local
Broadcast message from root (pts/0) Tue Apr  5 16:34:12 2011...
This example changes the AAA server from TACACS+ and no secondary source or tertiary source of authentication is configured.
device(config)# no aaa authentication login tacacs+ local
device(config)# show running-config aaa
This example configures OAuth2 authentication, with radius is configured as the secondary authentication, and the tertiary authentication is also configured.
device(config)# aaa authentication login oauth2 radius-auth-fallback local-auth-fallback
This example resets authentication mode to the default.
device(config)# no aaa authentication login oauth2 local-auth-fallback
