The string name of the required default MAC.
Your choices are hmac-sha2-256-etm@openssh.com,
hmac-sha2-512-etm@openssh.com, hmac-sha2-256, hmac-sha2-512, hmac-sha1,
hmac-sha1-96, hmac-md5, hmac-md5-96, hmac-ripemd160,
hmac-ripemd160@openssh.com, umac-64@openssh.com, umac-128@openssh.com,
hmac-sha1-etm@openssh.com hmac-sha1-96-etm@openssh.com,
hmac-md5-etm@openssh.com, hmac-ripemd160-etm@openssh.com,
umac-64-etm@openssh.com, umac-128-etm@openssh.com, and
hmac-ripemd160-etm@openssh.com. The default MACs supported in FIPS mode are
hmac-sha1, hmac-sha2-256, and hmac-sha2-512.
Modes
Global configuration mode
Usage Guidelines
The MAC hmac-md5 is not supported in FIPS mode.
Typical command example:
device# configure terminal
device(config)# ssh server mac hmac-sha1,hmac-sha2-256,hmac-sha2-512
device(config)# do show running-config ssh server
ssh server key rsa 2048
ssh server key ecdsa 256
ssh server key dsa
