Specifies the RMON alarm index. Valid values range from 1 through 65535.
snmp_oid
Specifies the MIB object to monitor. The variable must be in the SNMP OID format, for example, 1.3.6.1.2.1.16.1.1.1.5.65535. The object type must be a counter32.
intervalseconds
Specifies the RMON alarm sample interval in seconds. Valid values range from 1 through 2147483648.
absolute
Sets the sample type as absolute.
delta
Sets the sample type as delta.
rising-thresholdvalue
Specifies the RMON alarm rising threshold. Valid values range from 0 through 4294967295.
eventnumber
Specifies the event for the rising alarm. Valid values range from 1 through 65535.
falling-thresholdvalue
Specifies the RMON alarm falling threshold. Valid values range from 0 through 4294967295.
eventnumber
ownername
Specifies the identity of the owner. The maximum number of characters is 32.
Modes
Global configuration mode
Usage Guidelines
Enter
no rmon alarm to disable the alarm conditions.
