Specifies a VRF though which to communicate
with the LDAP server.
mgmt-vrf
(Default)
Specifies the management VRF.
default-vrf
Specifies the
default-vrf.
vrf-name
Specifies a VRF
name.
ipaddr|hostname
Specifies the IPv4 or IPv6 address or host
name of the LDAP server. IPv6 is supported for Windows 2008 AD server only.
The maximum supported length for the LDAP host name is 40 characters.
portportnum
Specifies the TCP port used to connect the
LDAP server for authentication. The port range is from 1024 through 65535.
By default, port 389 is used for the startTLS method and port 636 is used
for LDAP over TLS.
ldaps
Specifies that LDAP over TLS is to be used instead of startTLS.
domainbasedn
Describes the base domain name of the host.
timeoutsecs
Specifies the wait time for a server to
respond. The range is 1 through 60 seconds. The default is 5 seconds.
retriesnum
Specifies the number of retries for the
server connection. The range is 0 through 100. The default is 5.
source-interface
Indicates the type of interface to use as the source interface or address.
etherneteth-id
Specifies the Ethernet interface to use as the source interface,
in slot/port format (0/1).
loopbackloopback-id
Specifies the Loopback interface to use as the source
interface.
managementmgmt-addr
Specifies the management address (active MM or chassis IP) to
use as the source address.
veve-id
Specifies the VE interface to use as the source interface.
Modes
Global configuration mode
Usage Guidelines
Use this command to set up or change a
connection to the Lightweight Directory Access Protocol (LDAP) server host. A
maximum of 5 LDAP servers can be configured on a device.
Use the no ldap-server host
form of the command to delete the server configuration.
When a source interface is not specified, the default source is the IP address of the
interface from which the packet egresses.
If, at run time, the source interface is not up or the IP address for the source
interface was not configured, the command behaves as though the source interface was
not configured.
Invoking no on an attribute sets
the attribute with its default value.
This example adds an LDAP server on port 3890
with retries set to 3.
